John Deere Dozer Help
Discussion in 'Dozers' started by Gavin T, Dec 2, 2019.
  1. bccat
    bccat Well-Known Member
    Jun 12, 2010
    106
    Squamish BC
    I would go with 15/40 Diesel engine oil
  2. Gavin T
    Gavin T Member
    Dec 2, 2019
    19
    Clark Fork, ID
    Thanks!
  3. rmllarue91
    rmllarue91 Senior Member
    Apr 17, 2014
    484
    field technician
    northeast pa
    If it's up north I'd Use lighter oil. Drain bottom of oil compartments fresh fuel filters and send it them machines are Hardy
  4. doublewide
    doublewide Senior Member
    May 31, 2015
    297
    MA
    Do you have manuals for the machine. It should cover what oil the manufacturer recommends at various temperatures. I know some of the older diesels have smaller oil passages and were designed to run on a 30 weight diesel oil, especially at lower temperatures.
    Also, I believe this is an indirect injection engine (precup) and requires an external heat source to start, i.e. glow plugs. I have an International 282 that takes a full minute on the glow plugs before starting, no mater what the ambient temperature. Again, consult the manual for proper starting procedure.
  5. Gavin T
    Gavin T Member
    Dec 2, 2019
    19
    Clark Fork, ID
    Unfortunately not. I've been searching for one online to no avail. I did notice the glow plug indicator on the ignition so there's that.
  6. Labparamour
    Labparamour Senior Member
    Sep 6, 2013
    452
    Washington
  7. Gavin T
    Gavin T Member
    Dec 2, 2019
    19
    Clark Fork, ID
  8. Labparamour
    Sep 6, 2013
    452
    Washington
  9. chroniekon
    chroniekon Senior Member
    Apr 1, 2011
    273
    Albany, Or
    I have an operator manual for gasoline 2010 JD wheel tractor. I don't remember if it covered the diesel version or not. If you like I can dig the manual out tomorrow.
  10. Gavin T
    Gavin T Member
    Dec 2, 2019
    19
    Clark Fork, ID
    Do you know if it's the same engine? If so, I just need the preferred oil at this point. Thanks a million!
  11. chroniekon
    Apr 1, 2011
    273
    Albany, Or
    I don't know if it is the same. I'll take a look at it tomorrow, it's been awhile since I looked at it. Hopefully it has some info on the diesel version.
  12. chroniekon
    Apr 1, 2011
    273
    Albany, Or
  13. chroniekon
    Apr 1, 2011
    273
    Albany, Or
  14. chroniekon
    Apr 1, 2011
    273
    Albany, Or
  15. doublewide
    May 31, 2015
    297
    MA
    Great info there chroniekon!
  16. Gavin T
    Gavin T Member
    Dec 2, 2019
    19
    Clark Fork, ID
    chroniekon -- you are a lifesaver. I really appreciate it.
  17. chroniekon
    Apr 1, 2011
    273
    Albany, Or
    Glad to help.
    Edit: I just noticed you have the primer. It's the round knob on the lower left of the instrument panel.
  18. Gavin T
    Gavin T Member
    Dec 2, 2019
    19
    Clark Fork, ID
    Yep. I've run it many times as a kid, but once I left went off to college a lot of the knowledge was forgotten. I'd say it's 50/50 I get it started the first go.
  19. Gavin T
    Gavin T Member
    Dec 2, 2019
    19
    Clark Fork, ID
    Any clue on transmission fluid?
  20. chroniekon
    Apr 1, 2011
    273
    Albany, Or
