John Deere 9520R
mg2361
Pennsylvania
Equipment Mechanic
No I have never worked on one. However, I do have access to some information if you need it. Serial number would be a must.
mg2361
Pennsylvania
Equipment Mechanic
I looked at build codes to determine if your machine has high flow or not, suspended cab or not, but the page was blank. So I attached both cab and both pump procedures. The procedures for the two cabs and the two pumps look pretty close to the same.
  • 9520R Remove and Install Hydraulic Pump—Standard Flow Hydraulic System.pdf
  • 9520R Remove Fixed Cab.pdf
  • 9520R Remove Suspended Cab.pdf
  • 9520R Remove and Install Hydraulic Pump—High-Flow Hydraulic System.pdf
Dave Neubert
Monroe NC
Thanks a lot I have high flow and fixed cab as it is a scraper special. We suspect either something in the pump drive broke or pump shaft sheared. Was working fine shut it off at lunch came back and hyd. was dead
Vetech63
Oklahoma
I'm just going to go ahead and make one of those Nostradamus predictions and say the pump drive has stripped out.:)
