workshoprat92
Hey guys whats your thoughts and opinions on a Deere 710D? I am looking at one on an online auction. I made the 360 mile drive to go look at it. The machine has 9800hrs on it. Its set up with all that I want 4X4, extendahoe, 2 stick control, cab with heat. Only thing missing is an air conditioner but I think it can be added by using a red dot or carrier aftermarket kit so no biggie there. The transmission works through all the gears and pulls good and strong. The engine does not have a wiff of blowby when ya pull the filler cap which is incredibly suprising considering the hours. It was a county machine and they say they did oil changes every 200 hrs. Brakes all work good and will lock wheel no problem. Now for the bad. The hydraulics are weak. All the functions run and work but do not work with power. for example when you lower the outriggers they touch the ground lift the machine a slight little bit then quit. when you hold the controll and bottom a function the engine does not bog down or do you hear a relief blowing by. I figure the pump to be worn out or the destroking valve on the pump not working properly. also the swing pins have plenty of slop and really need to be reworked. Not sure how hard it is to do the main boom swing pins and swing cylinder pins? I also noted the hyd fluid level was so low you could not see it on the stick. You can see oil in the resivoir so its not so low it would cause the weak hyd issue. Also the trans fluid was so low it would not show on the stick. The bucket leveler does not work, it wont disengage from 4 wheel drive and the pivot point where the front axle mounts needs to be shimmed to get rid of a clunk clunk when you go from fwd to rev or vice versa as it slides forward or rearward on that shaft.
Ok so given all this it is probably the normal amount of problems for a machine with 9800 hrs on it. I think all can be dealt with and fixed. Only thing is I now know what I need to get it at to be able to fix he problems and not have more in it than the machine is worth. For the kind of work I do I am really sold on the size of this machine.
I have never owned any Deere equipment or ran them. Just wondering what your thoughts and opinions are on this model of machine????
