John Deere 690ELC issues
Discussion in 'Excavators' started by Ford tractor, Dec 3, 2018.
  1. Ford tractor
    Ford tractor New Member
    Dec 3, 2018
    3
    Ohio
    New to the forum.
    Borrowed a friends John Deere 690ELC for some farm work. Started it up for the first time when it was around 28 degrees. Slow to start but started and I let it idle for about 10 minutes. Drove it to a dead tree I wanted to push over. Everything was running fine. I had put it in E mode for this job. After dropping the tree, I noticed the engine idled down but then back up by its self. It did this another time before thumping to a stop. When I tried to restart it, it just made a grinding noise. I have tried charging the batteries up and still the same thing. I also jumped the starter and found it doesn’t seem to turn the motor. Kind of a grindy sound to it. When I turn the key to the “on” position, something activates Some kind of pump that sounds like it’s running rough. The starter it’s self wont engage with the key.
    Is there a switch or something possibly on or where should I look into so I can start this thing. Thanks
  2. Dave Neubert
    Dave Neubert Senior Member
    Jul 19, 2018
    443
    Monroe NC
    sounds like the starter stayed engaged pull starter it is probably toast
  3. backhoe1
    backhoe1 Well-Known Member
    Aug 24, 2007
    93
    South Dakota
    I had a 690ELC, went through a starter every year... Several times it stayed engaged and totally destroyed it
  4. Ford tractor
    Dec 3, 2018
    3
    Ohio
    I was kind of thinking the same. Any reason there is a loud humming/grinding sound when I turn the key to on though?
  5. Shimmy1
    Shimmy1 Senior Member
    Aug 14, 2014
    2,773
    North Dakota
    Starter is stuck engaged. When you turn the key on, it switches the battery disconnect on, which in turn powers the starter. Remove the + battery cable from starter and see if noise stops.
  6. Ford tractor
    Dec 3, 2018
    3
    Ohio
    Great info, thanks!
    Is there any fuel shut off valve on the 690sby chance?
  7. thepumpguysc
    thepumpguysc Senior Member
    Mar 18, 2010
    5,240
    Master Inj.Pump rebuilder
    Sunny South Carolina
    Yes.. if u have the Stanadyne inj pump.. theres an electric solenoid that shuts the fuel off..
    Its on/in the TOP COVER.. 2 studs + & -..12v
    The - is usually grounded thru the pump body so all you have to do is run 12v to the other stud..
    You'll HEAR it click..
