John Deere 60G Case Drain
Discussion in 'Compact Excavators' started by Andrew H., May 3, 2021.
  1. Andrew H.
    Andrew H. New Member
    May 3, 2021
    3
    Iowa
    Need to add a Case Drain on a John Deere 60G in order to run a Dougherty Tree Saw. Deere Dealer doesn't seem to be able to find anything. Anyone have any guidance on a part number/kit number available from Deere?
  2. lantraxco
    lantraxco Senior Member
    Jan 1, 2009
    7,609
    Elsewhen
    Do you have the aux lines kit on the machine, with a selective control valve for hammer/thumb switching?
    Will the tree saw case drain withstand the back pressure of a return filter or does it need to go direct to tank, ask the tree saw people.
    Vetech63 and mg2361 like this.
  3. mg2361
    mg2361 Senior Member
    Jul 5, 2016
    2,441
    Equipment Mechanic/Technician
    Pennsylvania
    Welcome to HEF Andrew;)!
    There is no "Case Drain Kit" available for a 60G from Deere. You would be on your own with that. Your best bet would be to contact one of the two outfits I attached links for below to see if they offer anything.
    https://www.hctkits.com/excavator-kits/
    http://www.hkx.com/
    Vetech63 likes this.
  4. Andrew H.
    May 3, 2021
    3
    Iowa
    Tree Saw people don't have any answers, Tee'ing into the return line that feeds the filter might be an option. I'll check that out, thanks
  5. Andrew H.
    May 3, 2021
    3
    Iowa
    Thanks! I'll check them out
  6. lantraxco
    Jan 1, 2009
    7,609
    Elsewhen
    And again, IF it has the aux lines kit with the selector valve for cylinder/hammer, the drain line for the hammer comes off that valve, you can disconnect it there and run a drain line to the end of the boom easily. This return does flow through the return filter so there will be some amount of back pressure.
    mg2361 likes this.
