This will sound a little odd, but when John Deere comes out, MAKE SURE that the flash update for the engine (injectors) is for the relevant machine. By this I mean Premium/non Premium, Quad box, sync shuttle ect. I recently had a 6230 that had transmission troubles. Showing low trans pressure at idle. When brought up 300 rpm's machine would stay in motion. JD cooporate thought it needed a reprogram and when it sent the update it did so with out making sure it was of the same tractor. Although engine and trans were the same on the update the other features like heat-A/C, blower, and other functions were wiped out during the program, which resulted with a new $500 module to be replaced, labor and mileage. Of coarse this was a goof up on cooporate, the tech didn't confirm, and I had one pissed off operator working in 100 degree heat cutting hay. This program also altered some engine controls too. The problem resulted in a bad transmission gasket between valve body causing fluid to divert to another port, thus cutting out pressure at idle/low rpm useage.
