alaskaforby4
We recently replaced the swing gear seal and when re-installing everything the machine will not rotate more than a few degrees back and forth.
We took the Planetary gear off and hung the motor, without planetary, hooked the lines up and it will still not turn.
There is fluid coming out the return line. It seems like the brake is not releasing.
Is there some sort of special bleeding or bleed port that needs to be bled?
When attempting to turn the motor will bog down some.
Any help or ideas would be appreciated.
