bsamot69
The warning light and buzzer have been coming on with the ECU code 97.16. water trap full. This happened to another operator. I changed the filter/ separator because I don't know it's age. I had drained a lot of water out of old filter, had cleared code and it ran okay for a bit , 20 minutes before light. Coming on.
1569.31 was also present when I originally heard the complaint. I was told the light come on and the machine was operated for a few minutes then it lost power. Now, I have installed the new filter and I operated the machine for over 45 minutes and the light came on. I shut it down before any power loss. Check the codes and the 97.16 is set. I drained the filter into bottle. It looks okay but not sure how to tell if there is water. Is there that much water in the fuel tank to keep setting this code? Any suggestions or similar experiences with this issue? Do John Deere ECU have a limp mode when operated with this warning signal active. That would account for the 1569.31 code.?
Thank you in advance for help with this
