You need to have your pump repaired.So I got to the machine today
Yep a wire right out of the top- didn’t see it before
Put test light on and machine fired right up- turned off after a min and light still on- not solenoid
Pulled the reurn line off the pump and started machine, fuel squirted out from pump making a mess but machine ran clear and dint turn off.
Cleaned check valve fitting and put back on- machine started and sounded clear then started to hesitate like before and then turned off
Removed check valve and machine ran clear and stayed running
With machine off fuel kinda built up and oozed out of top of pump with no line connected
I don’t really get the check valve on this as it doesn’t seem to be a check valve I am used to but now to search parts for where to get a new one from
Bob
