Tags
A customer of mine just purchased a very clean JD350B six way dozer that looks like it hasn't had much use or much abuse, like is usually seen on the small dozers. It runs very well, the issue is the left side will not steer while going forward unless you absolutely pull with all you've got back on the left side lever, works fine in reverse, and the right side works fine in either direction. Pushes through a pile fine with no slippage at all. I belive this is a dry clutch machine with hydraulic assist. Any ideas on where or what to start checking? The machine had been sitting for a whil too.
