John Deere 319D service codes
Discussion in 'Compact Track/Multi Terrain Loaders' started by Firescooby, Oct 14, 2021.
  1. Firescooby
    Firescooby Member
    Jun 13, 2006
    17
    Georgia
    I bought a 319D yesterday with 2150 hours. Is there a place that lists the JD service codes?
    Previous owner said that they have run with the fuel pressure sensor unplugged because when plugged in it derates.
    I am getting the following codes:
    94.04
    100.03
    523941.05
    523935.05
    96.04
    523935.06
    Thanks in advance
  2. mg2361
    mg2361 Senior Member
    Jul 5, 2016
    2,929
    Equipment Mechanic/Technician
    Pennsylvania
    Serial number?
    94.04 - low pressure fuel signal out of range low
    100.03 - engine oil pressure high
    523941.05 - auxiliary hydraulic retract output out of range low
    523935.05 - auxiliary hydraulic extend output out of range low
    96.04 - fuel level sensor out of range low
    523935.06 - auxiliary hydraulic extend output out of range high
    Key on then press and hold menu button until you are in service mode. Then you will be able to clear the codes. Run it and see what comes back (plug the fuel pressure sensor back in for this).
    Paul Council likes this.
  3. Firescooby
    Firescooby Member
    Jun 13, 2006
    17
    Georgia
    I’ll get the serial number.
    He said that every time you plug the sensor in, it sweated the motor.
    Any idea on possible cause or where to look?
  4. mg2361
    Jul 5, 2016
    2,929
    Pennsylvania
    First with a machine serial number I can check for software updates. There has been software updates that have addressed that code.
  5. Firescooby
    Firescooby Member
    Jun 13, 2006
    17
    Georgia
  6. tool_king
    tool_king Senior Member
    Mar 29, 2010
    1,894
    road mechanic owner
    new jersey
    What's your email address ? Can send you the manuals if you like .
  7. Firescooby
    Firescooby Member
    Jun 13, 2006
    17
    Georgia
    firescooby@gmail.com
    Thank you
  8. mg2361
    Jul 5, 2016
    2,929
    Pennsylvania
    There is a new ECU software available for that unit. Unfortunately Deere has not published what has changed yet. So I would recommend getting the software updated first to see if that resolves your issue.
    If you can, check fuel pressure with a gauge at the sensor port. Post results (idle and fast idle).
  9. Firescooby
    Firescooby Member
    Jun 13, 2006
    17
    Georgia
    does this have to be done at the dealer? Is it a free service?
    What fitting and fuel pressure gauge is needed for this?
  10. mg2361
    Jul 5, 2016
    2,929
    Pennsylvania
    Yes, it has to be done by the dealer and no, it is not free.
    As far as fittings I do not have numbers. You can either take your sensor to a hydraulic shop and have them fix you up or get some fuel hose, clamps and a tee and put your gauge between the fuel filter outlet and the inlet of the block - this is how I do it so I can look at fuel pressure in the monitor and at the gauge at the same time to check sensor accuracy.
