Order the elbow thinks I looked at that one it had Flare end ? Thanks all your help Mike
I haven't received the elbow yet. I call them twice they said it on it way? Is there anything else I can do. You probably have a idea of the problem.Order the elbow thinks I looked at that one it had Flare end ? Thanks all your help Mike
I tried the shifter all ready it don't move enough. The PM pressure never moved of zero psi during the shift from neutral. The forward clutch piston I would have to pull the transmission ? On filter I will give one more day to see if the elbow show up then I will pull the filter and cut it open. Thanks MikeI think on that machine you can put the shifter in neutral and then remove the 2 bolts attaching the shifter from the transmission and then you can install the straight fitting in the test port. You should be able to tell just looking at it if that would work.
I just want to confirm the shift solenoids are working properly (post #11) from the PM pressure. Also perform this test while plugged into the forward pack. I know you said "zero psi" but I would like to know if it shows pressure at all during the shift from neutral.
I suspect you have a forward clutch piston issue.
Also remove and cut open the filter. Is it full of clutch material.
I cut open filter and not bad at all very little shaving and the fluid looked good? the elbow will be here July 19PM pressure should have been something like 40 psi in neutral. You should see a neutral pressure of 39 to 43 psi at 1500 rpm. When you shift in either direction, the neutral pressure may drop by about 5 psi momentarily and then the modulation and pack pressure should ramp up quickly to 232 to 260 psi. This all should be accomplished in about 2 seconds after the shift is made. So it was zero in neutral and did not move when shifting into either F or R? Or 40 in neutral and dropped to zero when shifting into forward? Reverse?
Yes the trans has to come out for clutch repair.
PM pressure in neutral at 3 psi go to forward 3psi stays the same. Go to reverse 250 psi about 1.5 seconds.I cut open filter and not bad at all very little shaving and the fluid looked good? the elbow will be here July 19
I'm concerned at the 3 psi neutral reading. It is supposed to be 39-43 psi (@ 1500 rpm). When a shift is made that pressure should drop about 5 psi then ramp up to system pressure. If it drops to something less than 39 psi in one direction and not the other and stays low then that indicates clutch pack leakage in the pack it didn't rise in.
It can also tell you if the control valve is working electrically. If you have 40 psi in neutral and shift, even with a bad clutch pack, the modulation pressure dropping (any psi) indicates that the solenoids activated and shifted the spools.
What psi gauge did you use? If in fact all you have in neutral is 3 psi you may have more than one issue. Low neutral PM pressure is usually an orifice (C2 orifice) that came loose within the control valve allowing excessive leakage to the return circuit keeping the PM neutral pressure low and can sometimes make shifts take a long time. If reverse always shifts within the 2 seconds then the orifice is most likely in place.
This the psi gauge that I have been using. what should I do next I would like talk to on the phoneI'm concerned at the 3 psi neutral reading. It is supposed to be 39-43 psi (@ 1500 rpm). When a shift is made that pressure should drop about 5 psi then ramp up to system pressure. If it drops to something less than 39 psi in one direction and not the other and stays low then that indicates clutch pack leakage in the pack it didn't rise in.
I did the test on FNR forward run the jumper wire nothing. So I checked reverse it worked just to make sure. I will do the cooler today I need one more fitting. Going to check power again to the forward solenoidWith those backhoes, I am still skeptical of the electrical function (even though I don't like the PM neutral pressure). That has been 90% of the time the reason for a loss of one clutch issue with those units. Did you test the FNR with a voltmeter? Run a jumper from 12 volts to the forward wire at the FNR to bypass the FNR?
One last pressure test. Tee into your transmission oil cooler line (doesn't matter which) behind the grille with a 0-100 psi gauge. You may have to get creative to make the connection because there are no fitting numbers I can give you. You may have to follow the lines from the transmission to the cooler to know which cooler to tee into. Run the machine at idle and at 1500 rpm. Record the cooler pressure in neutral, forward and reverse at both rpm's.
No power going to transmission in forward or neutral x54 engine harness to transmission directional control only reverseI did the test on FNR forward run the jumper wire nothing. So I checked reverse it worked just to make sure. I will do the cooler today I need one more fitting. Going to check power again to the forward solenoid
Thanks for all your help I find the problem. There were four burned wires they were on the hydraulic line it was hard to get to but its running good. Thanks again MikeCheck the wiring where it runs over the top (right side) of the transmission control valve. The wires have a nasty habit of laying on the top of the transmission control valve cover bolt and rubbing thru either shorting (which you don't have because the fuse did not blow) or breaking the wires. Also check the connectors X23, pins 9 and 10 as well as connector X25, pins 15 and 16.
