Coaldriver
I have a 2 wheel drive 310c backhoe.
1989 model.
I need to build the steering cylinder.
The pin that holds the cylinder on the inside pin doesn’t allow a way to be removed. It simply has a bolt that goes through the pin with a locking nut on top. Remove the bolt. No way to grab the pin and pull up on it to remove. The pin also seems to be too close to engine cradle and axle mount. I know that I could put the bucket down and lift the axle and let the axle droop down to one side for more clearance. But, there is still no way to grab the pin. The inside bolt pass through hole is not threaded for a puller.
Anyone have tips on how to remove the pin?
I assume I can just pull the rod and gland/piston while leaving the barrel attached to the machine. But I want to inspect and repair the barrel. Possibly hone it etc...and inspect or replace the pin. Etc.
additionally, I also need to pull the gland and rod out. I removed the outer snap ring. But, it won’t pull out. The slap ring keeps the gland from going inward. How to remove gland and piston? Do I need a filler ring to remove it? I know I need a plastic filler ring to “install” it.
This is weird.
When it comes to rebuilding the steering cylinder, I’m concerned about using a hose clamp to compress the packing kit as well as getting the double lip seal in the outer gland. I’ve heard I can boil water to heat double lip seal.....etc...
By the way, the service manual is vague. The service manual speaks of a cotter pin that holds the inner barrel pin to the front axle mount for cylinder. There is no such thing. And I have differentiated between the 2x2 and 2x4 model in the service manual.
Need help please.
Thanks
1989 model.
This is weird.
Need help please.
Thanks
