mg2361
Did you test the pressures in both forward and reverse? Need to do that. Make sure the oil is warmed up as well (specs post #13). Post results.
Before you switch hoses maybe you could answer a question first. Are you saying that in going forward one pump has pressure and when you run the same track in reverse the other pump is feeding it?
The relief valves for the travel circuits are in the travel motors and not in the main control valve. Forward travel is one relief and reverse travel is the other relief in the same motor.
