JOHN DEERE 200D LC - Need help to track this solenoid valve
Discussion in 'Excavators' started by V10THUNDER, Mar 3, 2021.
  1. V10THUNDER
    V10THUNDER Member
    Mar 3, 2021
    6
    ARGENTINA
    Hey all, I’m writing you from Argentina. We have had this excavator on a halt for months now waiting for the spare part. It arrived few days ago but it wasn’t the correct one, this part came from the official John Deere dealership.
    These guys are slow and more often than not bring the incorrect parts when we order them, so, in an attempt to get it working ASAP, I’m looking for the solenoid and the solid tube kinda thing that is actuated by the solenoid itself, this “tube” can be seen in the picture sticking out. The solenoid itself was lost by the guys at the dealership (top quality service) so it’s impossible to track this piece now, at least for me
    All I can provide is a bunch of pictures, the box hasn’t got any numbers or serial codes so only an expert can help now. As you can see the box is behind the cockpit, below the air filter
    E090FAA5-63A7-4317-BA81-FC00E4E63F07.jpeg 8D9E5270-0999-442C-AB0B-B6C39C5B3570.jpeg
    So any help in tracking this part is very much appreciated. Thanks
  2. Chisumtrail
    Chisumtrail Well-Known Member
    Nov 26, 2012
    97
    Parts changer
    Texas
    AT322678 solenoid and spool???????????? complete valve AT322524??????????????
  3. lantraxco
    lantraxco Senior Member
    Jan 1, 2009
    7,695
    Elsewhen
    Yup and to break it down if you only need the coil and nut:
    Solenoid Valve Coil
    Part Number AT423342
    DescriptionCOIL, 24V SOLENOID 1500 WATT DIODE
    Nut
    Part Number T225294
    Bit of a mess because some parts supersede.
    mg2361 likes this.
  4. V10THUNDER
    V10THUNDER Member
    Mar 3, 2021
    6
    ARGENTINA
    Wow you guys are monsters, the local mechanics and parts stores couldn’t figure out what this part number was, they had no clue where to search from either...truly impressive
    Thanks a lot!
    Paul Council likes this.
  5. V10THUNDER
    V10THUNDER Member
    Mar 3, 2021
    6
    ARGENTINA
    Hey all again, it seems we have a problem again with this fan.
    Is there a way to make it work directly ie bypass the opening and closing of the valve so the fan is permanently working? At least to make it finish the job it has to do.
    Thanks.
  6. Vetech63
    Vetech63 Senior Member
    Aug 10, 2016
    3,604
    Oklahoma
    Only in America my fine friend!
    mg2361 likes this.
  7. Vetech63
    Aug 10, 2016
    3,604
    Oklahoma
    Post your machine serial number ..............and I'll give the Deere God a yell. Hey MG!!!!!!!!!..............Your needed!
    John C. likes this.
  8. V10THUNDER
    V10THUNDER Member
    Mar 3, 2021
    6
    ARGENTINA
    Here you go hehe
  9. mg2361
    mg2361 Senior Member
    Jul 5, 2016
    2,704
    Equipment Mechanic/Technician
    Pennsylvania
    What is the fan doing specifically?
    If you had repaired your fan and it was working normally, then try unplugging the solenoid to see if the fan goes to full speed. Otherwise see below. Bypassing the fan valve should get you to full fan speed.
    Another question, what's the ambient air temperature you are running at?
    John C., Vetech63 and LACHAU like this.
  10. V10THUNDER
    V10THUNDER Member
    Mar 3, 2021
    6
    ARGENTINA
    The fan stops when the machine moves, it doesn’t stop when it’s static but it also doesn’t speed up so the engine overheats if working with a generous throttle setting, ambient temp is around 5-15 degrees Celsius, during these winter months. Hotter months begin with September-October
  11. mg2361
    Jul 5, 2016
    2,704
    Pennsylvania
    Unplug the solenoid on the valve first. If the fan does not speed up then try bypassing like I mentioned. Post whether the fan increases to full speed or not.
    John C. and Vetech63 like this.
  12. V10THUNDER
    V10THUNDER Member
    Mar 3, 2021
    6
    ARGENTINA
    Yes it worked. We will leave it to finish the job and then disassemble the complete valve box thingy.
  13. heymccall
    heymccall Senior Member
    Feb 20, 2007
    2,940
    White Oak, Pa
    If unplugging = fan speed increase, the problem likely isn't in that solenoid valve, but rather the computer, or, more precisely, in a sensor that the computer uses to determine when to increase the fan speed.
    mg2361 likes this.
