Outdoorsman
I have a John Deere 120C Excavator that stopped running while working on the farm. The engine turns over but will not crank, I thought it was a fuel issue, so first I changed the filter, then next the little priming pump with the little leaver was changed. Then bought a new Injection pump and replaced. thinking that was it. I installed to all specs with timing the engine with the injection pump to 1st cylinder TDC. fuel is coming out the injection lines, so I'm pretty sure I have the system primed. but will not crank unless a little Starting fluid is sprayed in, if I spray the engine with starting fluid it will crank right up and run fine until I stop shooting bursts of starting fluid to it.
if I shut the key all the way off where I can remove it, then crank the engine it will have a little want to crank and acts like it for about 5 seconds then goes right back to just turning over. (without using starting fluid of course). If I do not turn the key all the way off where I can remove the key just to the point that it kills the engine, then try to start again, it just turns over and over without any want to crank.
Any thoughts of what I could do next to get it to crank and stay running!?
Please Help
Thanks
Please Help
Thanks
