I have two lifts that are giving me fits and i cant seem to figure out either one....
JLG 1200 SJP: I had a problem getting the outriggers out this morning and determined with a call to JLG that the horn wiring had come disconnected in the upper box. Yea, i know that sounds crazy but thats what it was. So, with that fixed the out rigger went out and everything worked as it should. When i was done checking everything and ready to put it away the from extendable wheels wouldnt go in. The rear ones closest to the platform go in and out just fine but not the front ones. I checked all four prox switches and they seem to be working. Not sure where to go with this next. Any ideas of what to check? When you try to retract them the machine does slow down like its getting a signal. The ground was ice covered so i think this is the best possible senario to be trying this....
JLG 80HX+6: The steering will not steer to the right. Yesterday i unloaded it from the semi and it acted up but snapped out of it till i went around to park it, then the wheel wouldnt turn again. I have located and checked the coil that activates this function. I put a wrench on it and it is magnitized. I also tried jogging the axle switch to see if it was maybe splitting power to both functions. It doesnt appear to be doing that. I also used a jumper to put 12v of power to this and no change. Checked the ground also. Any ideas on this one?
Thanks!
Thanks!
