Working on a sky track with a 4bt Cummins has slow cranking issue, load tested battery clean connections checked voltage drop tried a new battery customer put a starter in it 4 months ago, removed starter anyway and bench tested it is it possible hydraulic pump is putting load on engine causing slow crank?
