knares
the wires 5 and 6 from any of the PQ controls have only about 3 volts, No7 has 0
at the same time No3 still has 12v
Willie I have a JLG 45 HA when in creep mode the main boom will not lower I have to put it in rabbit to lower the main boom the boom will raise in creep mode. I changed all the PQ controllers and adjusted them as per information found on this forum. Can you give me an idea of what to look for? I tried to start a conversation with you but I guess I haven't figured out how to do that yet.You won't see 12V on 5 and 6. Those two terminals are the function outputs of the controller. The output on those terminals is Pulse Width Modulation, or square wave, it happens so fast you can't see 12V checking it with a meter.
Terminal 7 of the controllers, if it's used, is a 12V input from an external/separate source. In the case with this machine, it would be a wire from the creep (snail) switch. When you flip the creep switch it sends 12V to terminal 7 of the controllers, this input reduces the control output of the controllers (creep mode) for nice slow operations when you have the basket close to things.
