Well first issue I have is getting the old girl running. After spending some time on it today seems the Petrol system and maybe the LPG system have issues. Have ordered a fuel pump for petrol system and a filter etc as it was dry at the carb. But the LPG system I know nothing about, it does seem to be supplying gas but I'm not sure if its enough. Initially I thought it might be an ignition problem as the muppets that looked at it last have changed all the plugs but all 4 plugs are sparking up, will check the timing once I can find my Strobe light, but for now it starts ish but sounds like it only want to run on 2 cyclinders and only if you hold the throttle back to just off tickover.....
Anybody have experience with the LPG side ??
