rbcanaday
That's called an "anti dieseling solenoid" and yes it shuts of flow of fuel through the carb, JLG uses it to shut the engine down. That way, when you shut the engine off, runs till it dies, that clears the gasoline from the intake system, now when you switch over to propane there's no mixture interference from gasoline. Make sure that pin inside the solenoid will move in and out easily with your fingers, ethanol gas will cause those solenoids to get stuck. If it moves freely, put a jumper wire from a battery on the wire and ground the solenoid body, see if it clicks and works the pin. If it works, you likely aren't getting a signal on the wire going to the solenoid.
fixed one issue but still think solenoid is bad. It wasn’t getting power because somebody flipped the switch to lp.
Got that fixed but it doesn’t want to shut down without killing master switch. So I think the solenoid maybe isn’t closing off right. The bad fuel had corroded it pretty bad. We got it free and even tested it but something must be bad with it since it won’t shut off. Thoughts?
