JLG 40E stuck in slow motion mode
Discussion in 'Other Construction/Demolition Equipment' started by rookieatbest, Feb 23, 2017.
  1. rookieatbest
    rookieatbest Active Member
    Nov 29, 2014
    38
    Tampa
    98 JLG 40e Problem
  2. rookieatbest
    Nov 29, 2014
    38
    Tampa
    oh and I did replace the sevcon but have not replaced the motor controller. This may be my next purchase as I thought the Sevcon was the issue.
  3. rookieatbest
    Nov 29, 2014
    38
    Tampa
    Art,
    Can you try this to see if you have the same issue on your lift.
    From the platform, press the steering either left or right, doesn't matter which. The while holding the left or right steering press the boom function that was running slowly. Does your unit "kick" into fast mode by moving the boom faster?
    This is exactly what my lift is doing.
    Thanks
  4. dmbcia
    dmbcia New Member
    Jun 20, 2018
    1
    Lawrenceville, Ga
    I am new to this board and need some wisdom. I have read through previous posts on similar problems but have a new problem.
    I am Resurrecting a 1996 JLG 40E that has been sitting for a while.... re-packing hydraulic seals one-by-one. Batteries are charged and boom, turn table and steering function correctly. Since its last move 4-5 months, it has recently developed drive issue with the electric motors. From the platform, Lift moves both forward and reverse , only a few feet then Plug brakes apply and all functions cease (like a controller trip). I set it up on blocks with the drive wheels elevated (no load) same results. The only way to move again is resetting foot switch. No flash codes are visible on the JLG (Sevcon). I think it was replaced by previous owner. Part ID in the manual identifies controller as 7013310-40e. But label on the back of the JLG MOS90d DC controller Part # 7013311(with a Date code on the Sevcon is 10/22/01). Any suggestions?
  5. ARToolDoc
    ARToolDoc Member
    May 22, 2018
    5
    Dentist
    Arkansas
    I'm still trying to get my 1996 JLG 40e problems figured out. I am still having drive issues, low power with all brand new batteries. It moves, but any incline at all it seems to stall, as if it is stuck in "Creep Mode". From what I understand that up thru 1996, the controller did NOT have creep mode built into them. From what I can find, the controller for the 1996 40e manlift was a part# 1600175. The controller that is installed in my unit appears to be the aftermarket unit 7011942/E120-1226. I have a suspicion that this may be the problem. If this controller is from a newer unit that has CREEP, could it be the cause of the slow, low power issue? When I test the voltage it is over 50 volts, so that isn't an issue. I will be happy to provide a phone # for anyone who is knowledgable and would be willing to help me deal with this. Thanks!
  6. rookieatbest
    Nov 29, 2014
    38
    Tampa
    willie69 has experience with JLG. maybe he will chime in with some insight on both our units
  7. willie59
    willie59 Super Moderator
    Dec 21, 2008
    12,095
    Service Manager
    Knoxville TN
    I don't think those units used a creep mode on the drive motors, the drive joystick control simply sends input to the MOS90 motor controller for fwd/rev direction and proportional speed input. The MOS90 does everything from there. Have you checked the LED on the MOS90 to see if it's flashing any fault codes? Aside from that, if you suspect a problem with the MOS90, call Hindley Electronics and see if they can test the unit, or if they can't if they can recommend someone who can test it. It's been years since I've worked on one of those, but I do recall sending one off once to have it tested, just can't recall who I sent it to. Be sure and check all your contactors, look for evidence of one with burnt contacts or even one stuck.
  8. rookieatbest
    Nov 29, 2014
    38
    Tampa
    thanks for the recommendation, will call the start of the week
  9. rookieatbest
    Nov 29, 2014
    38
    Tampa
    It’s alive!!!!!
    After replacing all the least expensive items I have been running around chasing one problem after the next. I finally bought a new controller and everything works.
