Hello-
I have a couple JLG 400CRT rough terrain scissor lifts. One of them will not throttle up with you activate the movement functions like it is supposed to. It does all the functions, just at an idle.
I had a mechanic working on it and he said he thought he had tracked it to a bad relay. Unfortunately, he got sick with cancer before he could make the fix and he is not working anymore.
I looked around and the only relay I could find was the at the back of the engine near the throttle activation box. I replaced that but it didn't fix the issue.
Does anyone know if there are other relays located elsewhere on the machine, or does anyone have any other ideas as to what may be causing the issue I am having?
Thank you in advance for any advice!
