JLG 2032ES Scissor lift throwing 771 drive code OPEN CIRCUIT DRIVE MOTOR
Discussion in 'Forklifts/Telehandlers' started by actionpaintball, Apr 6, 2020.
  1. actionpaintball
    actionpaintball Member
    Feb 11, 2014
    6
    Hayes Va
    2032ES, will not drive. I have the diagnostic connector and displays 771 error code which translates to OPEN CIRCUIT DRIVE MOTOR wiring. Is this typically from a fault inside one of the motors? Controller? It beeps, then immediately stops in FWD and Reverse.
  2. skata
    skata Senior Member
    May 10, 2007
    769
    midwest
    open circuit sounds to me like a break in the wiring. could be a blown fuse too. check the wiring and connectors to the wheels.
  3. Txhayseed
    Txhayseed Well-Known Member
    Dec 23, 2019
    87
    Texas
    Did you ever get it figured out ?
  4. actionpaintball
    Feb 11, 2014
    6
    Hayes Va
    no=pushed the project to the side for now. I will sit down and test the windings with a mega ohm meter. Its still operational, just cat drive it right now.
  5. Txhayseed
    Dec 23, 2019
    87
    Texas
    I have only replaced a handful of jlg drive motor in probably 15 years. 771 is usually the wire harness from the controller to the motors . the like to get internal shorts right above there the clamp into the drive motor housing. I would suspect the harness first. Unhook the harnesses and get your meter out and ohm each wire out while twisting the harnesses. I would check the harnesses out really good. Not saying it cant be a motor but id lean towards the harness.
    skata likes this.
