JD450C
Discussion in 'Track Loaders' started by tuney443, Jan 6, 2018.
  1. tuney443
    tuney443 Senior Member
    Mar 19, 2006
    1,199
    excavating contractor
    Dutchess County,NY
    Just found a great CL find--a 1979 JD 450C track loader. Supposedly sitting for 20 years at a foreclosed estate. Got my buddy to haul it out of it's nasty frozen perch with locked up tight as a drum tracks with his 40 ton winch on his Peterbilt recovery truck in the middle of the night.Read that off peak DOT hours. Next day with some fresh new batteries and fuel I had that baby running like a champ. After a few hours though she would'nt stay running, apparently the governor rings in the injection pump went South.Talking South, I sent the pump out to O&C Diesel in Augusta, GA for rebuilding--WOW--$450, more than half of what rebuilders by me in NY wanted. Another old girl lives again.
    Coastal likes this.
  2. redneckracin
    redneckracin Senior Member
    May 20, 2010
    292
    Pittsburgh
    Let's see the pics! I have a 450 sitting at the house right now that still runs great. Make sure you check the front cross bar for cracks and missing bolts.
  3. tuney443
    Mar 19, 2006
    1,199
    Dutchess County,NY
    I've had about 6 350's and 450' s over the years.Still have my 1984 450D dozer that I bought new and still runs like new. Also have a 420 and 2 440's with Jimmy Diesels along wih other JD iron.What makes this find relevant is the wet clutches,those are hard to find on the cheap on CL finds.Pics coming.
    DMiller likes this.
  4. thepumpguysc
    thepumpguysc Senior Member
    Mar 18, 2010
    2,714
    Master Inj.Pump rebuilder
    Sunny South Carolina
    450.00?? did you mean LESS THAN 1/2 of what a NY rebuilder wanted??
    I guess O&C has been reading/visiting the HEF site & figured out what a pump REALLY costs to rebuild.
    Glad you gotter up & running..
    DMiller likes this.
  5. tuney443
    Mar 19, 2006
    1,199
    Dutchess County,NY
    It's like the part in the original Jurassic Park where Malcolm states" I'm always looking for the future X Mrs.Malcolm." In other words sometimes I get confused with double negatives, the more I think about it, the more confused I become. My English teacher wife has got her hands full, yes indeedy.lol
  6. tuney443
    Mar 19, 2006
    1,199
    Dutchess County,NY
    More to come.
    DMiller likes this.
  7. DMiller
    DMiller Senior Member
    Feb 22, 2010
    2,916
    Retired
    Old Stanadyne or Roosa Master pumps were really bad for the gov coupler disintegrating, remans around here will run $900 IF you can find someone interested in doing it. You got good and lucky.
    Should be a good little tractor, very nimble but small and light for really heavy work.
  8. thepumpguysc
    Mar 18, 2010
    2,714
    Just call me your 4 leaf clover.. Lol
    I love rebuilding them..
    DMiller likes this.
  9. DMiller
    Feb 22, 2010
    2,916
    Retired
    Actually pretty simple pumps, just a few special tools and techniques, but what would I know!!
  10. tuney443
    Mar 19, 2006
    1,199
    Dutchess County,NY
    Engine runs like a Deere. Hats off to O&C. Never got involved with tearing into a pump, that's why there's experts out there.Hopefully, the clutch and the left steering clutch just need adjusting, they're both not right.
  11. tuney443
    Mar 19, 2006
    1,199
    Dutchess County,NY
    Strangest thing happened while checking things with the belly pan off,was checking tightness on front crossbar bolts and not 1,not 2, but 3 bolts just broke off while tightening with hardly any effort. Going to be fun getting those broken studs out now but have lots of experience with drilling/easy outs.
  12. DMiller
    Feb 22, 2010
    2,916
    Retired
    Good luck! Most likely were fractured just had not busted the heads off, I too am getting SOME better at bolt removals.
  13. hillbillywrench
    hillbillywrench Active Member
    Apr 15, 2014
    41
    Ozarks, USA
    I worked on die-casting dies for several years, (some were over 45,000# assembled). Broken bolts were a daily occurance. We discovered that a simple air engraving pencil with a dull point worked surprisingly well. The combination of steady counterclockwise pressure and vibration would spin fractured bolts right out. Didn't do much for rusted/corroded, but good on fractured. MUCH easier and faster than drilling and EZ-out. Also doesn't interfere with drilling out if it doesn't work.
    I thought the older guys were jerking my chain when they told me to try it, but it really worked sometimes. It only took a couple minutes to try it. If it worked, then GREAT. If it didn't, then we started drilling.
    Yours are probably just a little rusted after that many years though.
  14. thepumpguysc
    Mar 18, 2010
    2,714
    HBW> that's a fantastic tip.. I JUST broke off a drill bit in a hole.. its not deep but I was looking for a solution.. THANKS, I'll give it a try when it quits raining.
  15. old-iron-habit
    old-iron-habit Senior Member
    Nov 23, 2012
    2,954
    Moose Lake, MN
    If that has the two speed forward with single speed reverse in the power reverser make sure you use the manual and adjust the linkages in proper steps as shown. A number of steps to do it right but its not a bad job. They all effect each other and many are messed up when folks adjust them without following the correct procedure.
    DMiller likes this.
  16. d9gdon
    d9gdon Senior Member
    Feb 12, 2010
    1,208
    central texas
    It's kind of like greasing an old Allis Chalmers combine from the fifties, it's a complicated process LOL.
    old-iron-habit and DMiller like this.
  17. DMiller
    Feb 22, 2010
    2,916
    Retired
    As to the locked up rails, freed up at all? If not soak 'em with water WHEN NOT FREEZING OUT and then run it for a trophy, water set the crap water will help remove the lock.
  18. Hobbytime
    Hobbytime Senior Member
    Sep 22, 2016
    546
    usa
    I saw that same machine on CL a few months back, I was looking for spare parts for my JD 355 track loader, but not much would fit so I passed on it..but better you bring it back to life, the CL add did say it needed track work...
  19. Hobbytime
    Sep 22, 2016
    546
    usa
    best way to get those nuts off are to put a flat washer down over bolt hole and then a big nut and weld to broken stud even if below surface with mig or stick and then unscrew, may take a few times but much easier than drilling and easy outs..
    DMiller likes this.
