SSChevy383
I was wondering if anyone knew where to get a hydraulic lift cylinder for 1981 JD450C?
I actually only need the barrel as the c clip groove inside is worn out. Is it possible to find just the barrel?
I found a used cylinder online for I think it was $850 but it is for a 1978. Is the 78 the same as an 81?
Does anyone have a parts diagram for the hydraulic cylinder with part numbers? The numbers in my book I guess are outdated cause I can't find anything when searching for some of the part numbers.
Thanks.
Thanks.
