Ricardo Cotte
Hello, anyone having the outlet fitting on the hyd pump loosening and causing a nuisance leak? Is tightening it periodically the solution or something else might be wrong? Like an o-ring not sealing anymore or threads needing sealant?
I am not sure the type of fitting and would like to have a replacement at hand before removing. The high pressure hose is OK and the leak comes from either the swivel or the adapter on the pump body.
Thanks for your comments.
