Looking for some help. Just got a JD CT 332 and the bucket tilt has a little issue.... While running the machine the bucket wants to tilt up on its own. Seems like it does it more while at higher rpm's. You can bump the right joystick to the right or dump and it will quit for a few minutes. Also when it does this, and you move the right joystick to the left more than just a slow dump, it dumps fast and if you keep moving to the left it is like it is in a neutral position and will not move. Just found the calibration instructions and will try that tomorrow.
Any help is greatly appreciated.
