JD Autotrac and a Sleepy Operator
Discussion in 'Agricultural Operations' started by flametamer, Nov 3, 2015.
  1. flametamer
    flametamer Well-Known Member
    Jul 26, 2009
    52
    Biomed Tech, Towing
    Benton, Mississippi
    Autotrac did its job, it kept the tractor going straight. It didn't know there was a river it its way. Driver wasn't hurt, just now unemployed. Unbolted the hitch and slowly pulled the planter back. We picked the front of it up with the tow truck to keep anything from getting bent. They owner used a forklift and backhoe as brakes if you will to slowly let the planter roll forward. Once it was out of the way, they dug a ramp out for use to pull the tractor up. No damage. Total time, 5 hrs.
    Dt
  2. lantraxco
    lantraxco Senior Member
    Jan 1, 2009
    6,684
    Elsewhen
    Bet that was a rude awakening.....
  3. CatToy
    CatToy Well-Known Member
    Nov 2, 2014
    245
    SE Tn
    oops!:eek:
    Begged my grandfather for two years to let me run the planter, finally turned me loose in a 250 acre field late one afternoon with the planter. Only one tree in the whole field, he warns me not to get locked in watching the GPS row marker and hit the tree, well, guess what, I did. I was fired also.
  4. flametamer
    Jul 26, 2009
    52
    Biomed Tech, Towing
    Benton, Mississippi
    I tried to talk them into sealing the saddle tanks and seeing if it would float down to the boat ramp. The didn't see the humor in it.
  5. Richardjw~
    Richardjw~ Senior Member
    Apr 14, 2007
    307
    South Devon, U.K.
    how have you got them saddle tanks supported at the back? Is that the free-wheeling hub design right on to the bar axle like i saw on Ag-Talk a few years ago?
  6. Richardjw~
    Apr 14, 2007
    307
    South Devon, U.K.
    ....and good job no crocs in the river :)
  7. flametamer
    Jul 26, 2009
    52
    Biomed Tech, Towing
    Benton, Mississippi
    Demco Side Quest tanks. Yes, they do mount to the rear hub.
    Dt
  8. old-iron-habit
    old-iron-habit Senior Member
    Nov 23, 2012
    3,371
    Moose Lake, MN
    I can't help myself. I have to say this. "Some people would rather fish than work."
  9. Paystar
    Paystar Well-Known Member
    Mar 14, 2008
    189
    trucking owner/operator
    Ontario, Canada
    I'm amazed there was damage to anything. You would think the hitch would have got tweaked at that angle.
  10. flametamer
    Jul 26, 2009
    52
    Biomed Tech, Towing
    Benton, Mississippi
    No damage. The hitch was in a bind though. They wanted to try unbolting the top of it first, before cutting it apart. After folding the wings up(by using a 2nd tractor and long hydraulic hoses), the tow truck taking pressure off of the hitch and was able to separate the two. It was a steep drop, but not truly vertical, so that helped.
    Dt
  11. ol'stonebreaker
    ol'stonebreaker Senior Member
    Apr 26, 2015
    328
    retired
    Idaho
    I wonder if texting had a hand in that??
    Mike
  12. flametamer
    Jul 26, 2009
    52
    Biomed Tech, Towing
    Benton, Mississippi
    Sleep. The tractor was in Autosteer, so the operator was just sitting there. It was a long field, so he wasn't turning around often. Add in the drone of the engine...
  13. td25c
    td25c Senior Member
    Feb 15, 2009
    4,921
    indiana
    Time to go back to open station tractor & planter markers .:D
  14. ericscher
    ericscher Well-Known Member
    Sep 12, 2014
    196
    Central Ohio
    HA! You think I can't fall asleep on that?
    I'll show you!
    zzzzzzzzzzzzzzzzz
  15. td25c
    td25c Senior Member
    Feb 15, 2009
    4,921
    indiana
