JD 644k exhaust filter restricted
Discussion in 'Wheel Loaders' started by kevman6, Jul 1, 2022.
  1. kevman6
    kevman6 Well-Known Member
    Jul 10, 2016
    176
    cadillac, Mi
    I have a JD 644k ser # 1DW644KZCCE650076 with a restricted exhaust filter and engine power limited. The parts catalog doesn't show a filter unit, or DPF. I think it is referring to the exhaust gas recirculation system. Warning says it needs cleaning. Parts catalog also shows an EGR valve, and a Heat Exchanger. I would think the restriction usually occurs in the heat exchanger, but not sure. Any help and knowledge is greatly appreciated.
  2. heymccall
    heymccall Senior Member
    Feb 19, 2007
    3,779
    White Oak, Pa
    Sure looks like a DPF unit to me.
    Used to be that you just needed the last 6 digits of S/N for lookup, but, you now need the E in front of the last 6 digits, too.
  3. kevman6
    Jul 10, 2016
    176
    cadillac, Mi
    Yes it does. Thank you for the diagram. Manufacturer info-video on the emissions system show that ash builds up and needs to be cleaned at about 5000 hours. It also says conveniently, John Deere has an exchange program for cleaned ones. Seems strange that we have just 5025 hours on the machine and this happens.
    I have read that some owners clean the unit themselves, but do I still have to get field service to clear this derate controlled by the ECU? Any experience on cleaning these?
  4. kevman6
    Jul 10, 2016
    176
    cadillac, Mi
    Any tests for checking the sensors ahead of cleaning?
  5. heymccall
    Feb 19, 2007
    3,779
    White Oak, Pa
    It was a $1000 to have dealer R&R dpf, have it cleaned, reinstalled, and run a regeneration on our 544k, all at 11,300 hours. That was the first time the dpf was serviced.
    DB2 likes this.
  6. kevman6
    Jul 10, 2016
    176
    cadillac, Mi
    Thanks, it would figure that the dealer would require you to have them reset the ECU. Cats are nice because you can do a forced regen.
  7. heymccall
    Feb 19, 2007
    3,779
    White Oak, Pa
    You still need a dealer once the soot load is calculated over, IIRC, 130%.
    DB2 likes this.
  8. kevman6
    Jul 10, 2016
    176
    cadillac, Mi
    I did a code clearing yesterday, but the restriction code remains and RPM is limited because of the DPF restriction code.
    I tried a regen on the exhaust filter, but it would not go past 38%. I assume that is because of the limited RPM. The regen would probably need a higher RPM required for filter regen completion
  9. mg2361
    mg2361 Senior Member
    Jul 5, 2016
    3,570
    Equipment Mechanic/Technician
    Pennsylvania
    What specific codes do you have? List the ones you deleted to, if you recorded them.
    BigWrench55 likes this.
  10. kevman6
    Jul 10, 2016
    176
    cadillac, Mi
    Code DPF 3719.0 Service required ECU
    Filter cleaning required
    contact service rep
    occurrences 62
    first 5011.8 hrs last 5025.9 hrs current 5026.2 hrs
    That's the only one that showed up with
    Engine speed 189.31
    Derate active ECU
    Speed derate
    Condition exist
    same hours as above
  11. mg2361
    Jul 5, 2016
    3,570
    Pennsylvania
    3719 code can only be cleared with a service regen initiated through Service Advisor, or possibly might require a DPF Recovery procedure through Service Advisor.
    That code by itself is the end result, so something else is is causing the DPF to plug up.
    Is the exhaust system setup in the monitor for automatic regens? If it is disabled that could be a cause. Does the operator shut it down when regen starts? A leaking injector or dosing injector, lots of idle time or low load running, low engine operating temperature are some of the things that can cause the DPF to plug.
    There are 3 DPF soot load readings in Service Advisor that can help determine issues and whether the DPF needs to come out to be cleaned.
    If it does not or cannot complete a regen, and there are no other codes, then there are 4 tests that will need to be done:
    1. Regeneration Abort Source Identification Test
    2. Exhaust Temperature Management Test
    3. Fuel Dosing System Air Purge Test
    4. Fuel Dosing Pump Diagnostic Test
    These all can only be performed with Service Advisor.
    So, basically, you now need the dealer to take over, or an independent who has Service Advisor.
  12. kevman6
    Jul 10, 2016
    176
    cadillac, Mi
    Thank You mg, we removed the DPF and cleaned it with a pressure washer. I didn't think it was that dirty inside compared to some of the videos if have watched. We have a call in for field service. DPF code was tripped when we bought the unit' but my guess is a lot of idle hours and no one allowing it to complete regen.
  13. kevman6
    Jul 10, 2016
    176
    cadillac, Mi
    Well, JD service came out and checked a few things. He did a service regen for awhile, but got a message to use a higher level for regen. Started the regen over and nearly two hours passed and it wasn't complete. He checked the time required and it calls for 3 hours and 10 minutes. Long story short, his day was over and he said he would be bake today to start over. The JD644k finally took the regen, and tech gave us credit for some hours yesterday. DPF cleaning did do a good job
    DB2 likes this.
