This tractor has what is called a DIESEL STARTING FLUID ADAPTER-----You remove the squirt nozzle and push the can up into the adapter and push the can up while rolling the engine--injecting either into the tractor.
I don't like using ether but this tractor-loader needs a sniff to start even after being plugged in to heat the water. Not sure how warm the water is getting....loader is probably a 1972.
Just looking for some thoughts from the brain trust here--thank you len
