Jd 544K over fueling
Discussion in 'Shop Talk' started by nowing75, May 17, 2022.
  1. nowing75
    nowing75 Senior Member
    Aug 5, 2009
    805
    coatesville indiana
    We have a 544K jd loader s/n 1dw544kzchf683777. Operator says it started runing bad and white smoke> our other mechanic looked at it and had codes for cam timing and pump timing. We only have a few mechanics so the larger jobs we have to give to dealer unfortunately . Hear is what they said seams odd to me so i wanted to get other peoples experiences. thanks for any input you might have.
    thanks
    Jason
    Machine is currently tore down to the point of the root cause. Root cause two injectors were stuck wide open. This caused the engine to stop running. This engine has been over fueling for an extended period of time. This caused many of the components to become plugged. The inside of turbo passages and EGR cooler are filled with sludge. This will need to have the head removed to clean sludge contaminants and check for warpage and cracks. The EGR cooler replaced. Replace all 6 injectors. Estimated repairs $17,000. Mechanically no engine damage is apparent at this time. Please advise on how to proceed so we can get parts coming by the end of the day today.
  2. Vetech63
    Vetech63 Senior Member
    Aug 10, 2016
    4,631
    Oklahoma
    From this statement...........what other choice is there? Does it seem high.....of course it does! Could it be done cheaper and with less work? Of course it can, if you request it.
    mg2361 likes this.
  3. heymccall
    heymccall Senior Member
    Feb 19, 2007
    3,797
    White Oak, Pa
    I dont see DOC and DPF cleaning listed there either.
    TNB and mg2361 like this.
  4. mg2361
    mg2361 Senior Member
    Jul 5, 2016
    3,593
    Equipment Mechanic/Technician
    Pennsylvania
    If you are under 3000 hrs then you still had emissions warranty left. The injectors would have been covered as well as all the residual damage. Since you disassembled it you lost your chance.
  5. nowing75
    Aug 5, 2009
    805
    coatesville indiana
    Heymccall we noticed the same thing.
    we did not take it apart it was the deer dealer
  6. mg2361
    Jul 5, 2016
    3,593
    Pennsylvania
    I'm guessing it has more than 3000 hrs?
  7. nowing75
    Aug 5, 2009
    805
    coatesville indiana
    Yes it does. Just was curios if anyone has had the sludge problem. Guys in the field did not see it smoking and was running fine,they fuled the machine and shortly after it started white smoke then it died and would restart. found it funny also that 2 injectors failed at the same time.
  8. thepumpguysc
    thepumpguysc Senior Member
    Mar 18, 2010
    6,324
    Master Inj.Pump rebuilder
    Sunny South Carolina
    After refilling, they stirred up a bunch of sludge and water..
    ALL the injectors were feeding off the same “teet” so to speak..
    Therefore it’s not uncommon for 2 or more injectors to get stuck.
    Time to change the filters on the fuel tank/fuel truck..
    nowing75 and Vetech63 like this.
  9. terex herder
    terex herder Senior Member
    Nov 10, 2017
    957
    Kansas
    If it doesn't have a dpf, you could just replace the injectors and run it hard and see if it cleans out. If all it does is load off a stock pile you probably can't run it hard.
