Ok so I'm out here in AZ helping on the ranch for the week, finally getting a chance to look at this in person. The new water pump and thermostat that JD installed did not fix the problem. Same symptoms as before, runs great for a while, then starts running bad when warm, also temp gauge does not work. Seems to be burning coolant as well, level is dropping and it's not going in the oil, not leaking externally. Suspecting bad head gasket or cracked head. I'll dig in a little deeper this week, but I'm working with limited tools out here, don't have my cooling sys pressure test kit, IR thermometer, etc. Any other ideas to check?
