Dirty530
I have a john deere 450h that has a fuel related misfire , ecu 1076.0 code of the dash. blocking the return line partially or fully stops the problem for a moment then it ethier dies or begins to misfire again, then injectors have been replaced tank drained and inspected fuel lines gone threw and then gone threw again, ecu inspected pins look fine, the plug for the solenoid test at 4.2 volts when it's off and climbs with the machine when it's running and throttled up until the misfire starts then bounces with rpms when the misfire begins (usually around 1300 rpms ) is my injection pump done? I've already foolishly bought injectors already and I'm a little gun shy n burning another thousand on a shot in the dark
