Spiva Const
- Joined
- Sep 28, 2016
- Messages
- 57
- Location
- Camino, CA
- Occupation
- Retired underground utility contractor
My 444J has an error code of 100.4. This code is engine oil pressure open or short. The dashboard gauge module shows no movement on the oil pressure gauge or any of the other gauges after the initial check mode when the key is turned on. All gauges move to the right stops and the red lights light up on initial test cycle then return to a random position. I checked the harnesses to the dash module and the other controllers behind the panels on the right side of the loader. There is no apparent rodent damage or frayed wires. I applied die electric grease to all the connectors.
I’m looking for some best guesses as to where to start, possibly replace the dash module or engine controll unit.
