Jd 444E slow high speed...
Tags
Connecticut
We have a Deere 444E wheel loader with about 5000 one owner hrs on it, it has had a relatively easy life and doesnt get used hard or often. It seems that when we travel on the road with it the high speed doesn't seem to be as fast as it used to be, low speed is fine, it goes into a pile no problem. It has been serviced regularly and we recently changed the trans filters and fluid and it hasn't made a difference, anyone have any thoughts on what to check next??
Viper881
Michigan
Did you ever figure out what the problem was? We are having the same issue
Tags
Connecticut
Nope! Never figured it out but did not try that hard either, shortly after I posted the problem we sold the machine, guys that bought it didn't seem to care....I would use the "start a conversation" feature (private message) with a member that goes by mg2361, he is a Deere guy and is incredibly knowledgeable and helpful, he was not here when I posted. Have your serial number handy....
mg2361
Pennsylvania
Equipment Mechanic
Welcome to HEF Viper;)! Serial number is a good start. First thing to check however regardless of the serial number is the inching pedal cable/linkage/valve. From the left pedal there is a cable that runs back to a lever on the transmission. Make sure the pedal and the linkage as well as the lever on the transmission the cable is attached to returns completely when your foot is off the pedal.
Viper881
Michigan
Hi mg2361,
The serial number: CK444EB000537
I will dig into that first right now. I changed all fluids and filters for Hydrulics and trans hoping it would help, and it did not.
Viper881
Michigan
The linkage/valve returns to the correct position by the transmission.
Another thing I attempted:
I put it in first gear and could spin the tires trying to push in the loading dock. The 2 front tires both spun, and one of the back ones would. Neither back one spun at the same time as the fronts did.
In the manual right next to the “adjust inching pedal” page, is the “adjust front axle disconnect cable.” I do not see that cable located in the cab or on the front axle. Not sure if that/what I’m explaining, could be a problem, or part of the problem of why it would go over 9mph in high gear.
mg2361
Pennsylvania
Equipment Mechanic
You do not have that "option" on your loader based on the build codes for your serial number.
Sounds like it may be a motor displacement control valve issue. So you have the tech manual TM1421? Time to check pressures. If you go to page 9020-25-5, right side of the page, follow (D) for transport speed slow diagnostic procedure and (E) speed is slow and power is good procedure.
Viper881
Michigan
I have the tm1422....it only goes up to 3160-24 and then jump to dealer fabricated tools group 9900-1. Do you have a picture of the page that I good use to follow?
mg2361
Pennsylvania
Equipment Mechanic
Viper881
Michigan
