Pressure in revers and nuetral was 135 +, that's on the bottom test port
Oil is full and new, new filters. just cleaned the screen,
Tested the top test port front zero pressure, didn't get to the rear test yet
Did clutch adjust to get the pressure where it was and the free play is close to perfect
All hydraulics work although they are a little slow and weak
Pressure test on the main pump reads about 2400 at cold start and drops to a little under 2000 when full warm, I think my stroke control adjustment is frozen, cant adjust pressure.
Thanks for the help
What was the pressure in neutral? Reverse? Where did you take that pressure?
Is the oil level good? Suction screen clean? New filters?
This one is important - Clutch adjustment adjusted properly?
Do your hydraulics work?
Check the charge pressure to the hydraulic pump and post the results please.[/QUOTE]
