southernman13
Picks up a. 322 with 4024T engine. I believe it's an 07'. Had been in water and they have had it running since but hasn't ran in 6 months or more. They couldn't figure out anything. So far I've found broken wire going to relays and wire going in fuse panel was pushed out. They replaced the starter but I think it was the wiring issue and they were throwing parts at it. It's a low hr unit (1400) and looks really good and not abused. I know have power and it turns over etc. it still has radiator out and many items need to be put back on. Before I replace everything I wanted to make it run. I pumped primer pump on top of fuel filter and it's tight now. How do I bleed the fuel system in this engine. It turns over and smokes a little but has busted off yet. Thanks in advance.
