fred rosenberg
So my JD 310D wont go into to forward or reverse, after sitting for about 2 months. I drained the main hydraulic tank, to change out the starter which was intermittent (moving that main hyd hose makes access to the bottom starter bolt easier)put the rebuilt starter back in, serviced the hydraulic reservoir, and boom- it still wont start. Thats the least of my problems now. After shorting out the two solenoid terminals she started- but now, she wont go into forward or reverse. Nothing- not even a little bump either way. Checked the revwrser dipstick, plenty of fluid, if anything its over-serviced. Never had an issue before. Started crawling around underneath, found a connector with bare wires going to a solenoid on the reverser. I dont know if the insulation had degraded, or a rat chewed on them, but they were bare, going into the connector. My parts manual shows this as the “Reverser dump solenoid”. (#10 in the pic) I tried to strip back the wires to make a splice/repair but that heavy metal braid wont let me. Im leery of pulling this “Reverser Dump Solenoid” and opening yet another can o worms, if any dirt gets in there. I guess i really dont have much choice, that metal braid insulation is not letting me get at the wire so I guess Ingotta pull it to make a splice. Any ideas?
