Southbus
Hi Folks
Today I tried to change the oil in the backhoe inverter, remove the cap and about 4 liters were drained and according to the manual the capacity is 7 liters, so I tried to put 7 liters thinking that it was missing but it was filled before putting the 7 liters And then when starting the engine more oil spilled and it looked a little dirtier.
So I suppose there was indeed a lot of oil left inside, perhaps in the torque converter and for this reason the system was saturated.
Is there a way to drain all the oil from this system?
or maybe a technique to remove as much fluid as possible.
I appreciate your advice.
Cesar
Cesar
