corrinne
Can anyone help me .. need to remove a steering wheel from a 2007 JCB 550/170. I was hoping to find a video but no luck. Hoping someone in this forum can help me. Thanks in advance!
Thank you will give it a try!Pop the plastic JCB cover off with a screwdriver. Use a 22mm or 24 mm and loosen the nut. Back it off till it's still on two threads. Get your very strong assistant in there and lift hard on both sides of the wheel at 9 and 3 o'clock.. they're tight but that's the way to get it off.
Thank you!or remove nut and pull out on wheel and tap on the center shaft with a hammer. be careful not to ruin threads.
I like to loosen the nut and wiggle/pull the wheel off. DO NOT remove the nut just loosen it.Can anyone help me .. need to remove a steering wheel from a 2007 JCB 550/170. I was hoping to find a video but no luck. Hoping someone in this forum can help me. Thanks in advance!
