hfptm
I'm trying to pin point or at least narrow down a few areas to check - my IT24 does not have accessory power in the cab when the key is in the on position and the main switch is on, it starts up fine, and cab power is on when the machine is running. transmission will not engage in forward or reverse, the back up signal sounds when put in reverse but the machine will not move. when gear selector is in the park or neutral position the fuel shut off solenoid chatters off and on. suggestions??
