Is this the proper way to install front motor mounts on a 580K phase 3?
nilzlofgren
New Jersey
IMG_0183.JPG Is this the proper way to install this front motor mount? Also, if this is the way, I'm assuming this is the correct orientation of the mount?
nilzlofgren
New Jersey
I do have the large binder type service manual. Thank you. Just wondering though, Why crankshaft alignment is an issue?
pepesm32
Mexico
So, does one mount go on the bottom and the other on top? Or do both of them go together in between the chassis and base?
alrman
QLD Australia
Welcome to HEF @pepesm32
The mounts you have pictured are for a 580L or 580M not 580SK as per thread title.
However, the tall part with steel spacer, goes in under the carrier, the donut ring is fitted above the carrier.
NH575E
North, FL
Retired Machinist
I don't know anything about this machine but thought I would add a side note for anyone that is interested.
McMaster Carr has mounts like this. If you have dimensions they might save you some coin. I recently bought and used some on my NH.
joe--h
Utah
Kinda late now, but you might want to plug those hydraulic lines before you fill them with dirt.
Joe H
