mg2361
PM me your email and I'll send you everything I have for regulator adjustments in one shot. The most important adjustment you will make out of the procedures will be the engine pulldown adjustments.
sounds like the swash plate is sticking(common problem) You can replace the swash plate and the rear cover on the affected pump cheaper then the whole pump. Remove the pump cover bolts and remove the swash plate.It may look like a gravel road .If you are really hard up for cash you can try and polish both surfaces but you can have success by replacing both.
Joeblow, are you saying pull apart and look at ‘B’ and ‘D’ (see pic) and if not smooth, replace those pieces?I assume you need to remove the pump from the excavator to do this?
