Shimmy1
2005 D6N.
13k hours on the clock. Latest oil sample says elevated particle count, continue to monitor and consider kidney loop to clean up oil.
Machine is having an intermittent trans output speed sensor fault. Techs have determined that it's not external harness, likely sensor or internal harness. Trans has to be pulled to replace either.
$5000 for R/R trans, internal harness, and both senders. Do I pull the trigger and have it done, or let it ride until the senders fail completely? Do you pull and put back in a 13,000 hour transmission?
What a pisser. Why can't these manufacturers design in access for these chicken**** electrical components that are destined to fail after the first start???
