DirtIsMyName
I am looking at a 1987 S1954 18' box truck. It has a DT466 and a seven speed trans with 4.44 gears and single axle, 31K GVW, air brakes. It's a one owner truck with 320K miles. This is probably not the truck I really want but I have to start somewhere and this one is here in town, pretty cheap, and doesn't look too bad.
What I am working towards in a truck is a Toterhome. I want to pull a 24 foot or larger enclosed trailer to motorcycle events. I would also like to use it to tow my 580L backhoe on a 24K pound backhoe trailer, 5K pounds empty.
I don't like to spend a lot of money on something and then decide it is not really what I want. That is the motivation behind cheaping out on this. If this isn't really what I want I'll know enough after this to buy or build what I do want next time.
I am guessing the truck would pull the backhoe OK with no other load but if I put RV stuff in the box for the Toterhome part of the package it might dog it out. I want to run it at hiway speed and don't think the gearing is right for the road. Not sure it has the guts to pull the load and higher gearing.
One concern is the age. Can I get parts to keep it running and if it broke out on the road would I have a long wait for parts to get going again?
Would gearing for an economical 70mph be possible and could it be done with a transmission swap or would I need to change rear end gearing? It looks like there are a lot cheap 13 speeds out there, is is a feasible swap?
Is it reasonable to install a sleeper kit conversion to make a pass through to the box from the cab?
They want $2500 for the truck and I'm told that is too much, what do you think? The truck has probably never seen salt so rust is not a big issue.
If it doesn't work out is there any market for the truck or parts from it?
