IR V530
Discussion in 'Forklifts/Telehandlers' started by tool_king, May 10, 2020.
  1. tool_king
    tool_king Senior Member
    Mar 29, 2010
    1,679
    road mechanic owner
    new jersey
    Hi guys
    Working on a IR v530 that is will not drive forward or reverse .Parking brake is released but shows brake symbol light on dash with exclamation mark . I check all the fuses . Any one have experienced this ? Does anyone have a service manual in pdf form they could email me.
  2. John C.
    John C. Senior Member
    Jun 12, 2007
    8,295
    I don't have a book but was just wondering if this machine is a telehandler? Is the parking brake manual or some kind of electric or hydraulic control?
  3. tool_king
    Mar 29, 2010
    1,679
    road mechanic owner
    new jersey
    Yes John it is a telehandler. Machine has hydrostatic drive system looks like .Parking brake is manual lever with electric switch that triggers a different light to come
    on.Lever is all the way down .I tried disconnecting the switch but just makes the light not come on .IT sold this devision out the Volvo.
  4. excavator
    excavator Senior Member
    Oct 16, 2006
    1,029
    Pacific North West
    I have a customer with one and never have been able to find a manual. I'm sure they're out there but not sure where.
  5. tool_king
    Mar 29, 2010
    1,679
    road mechanic owner
    new jersey
    Can you copy the operation manual from it .This one does not have have one at all so stuff is a pain .
    Thanks
    Ed
  6. excavator
    Oct 16, 2006
    1,029
    Pacific North West
    Not sure if it has one and it's in an oil refinery so getting to it is a pain. I'll see what I can do.
  7. Txhayseed
    Txhayseed Well-Known Member
    Dec 23, 2019
    151
    Texas
    If its a mechanical parking brake it could release or not and usually you can still drive the machine. Hence the light. Replaced alot of pads where customers drove around with brake on. If you suspect the brake is not releasing you can block the wheels drop the handle and go under and see. I dont think the parking brake is causing your no drive issue. It would still engage but with resistance from the brake drag. The parking brake should have just a simple switch that opens or closes when the handle or part of the handle makes contact turning off the light. As far as no drive forward or reverse id check my F&R switch switch. Check over on skyjacks web site. Skyjack bought ingersoll and continued using the same design for a good while. Didn't change much for a number of years. I was able to use a skyjack manual for an older vr1056 wiring schematic not long ago.
  8. John C.
    Jun 12, 2007
    8,295
    Did you get the V530 figured out and fixed? I ran into a parking brake issue on the Terex I've been working on. It has a hydraulic normally closed switch that is teed into the down stream of the parking brake valve. Park release is done using pilot pressure and when the hydraulic pump died, so did the release pressure for park. Not enough pressure and the switch stayed closed and would not release the brake.
  9. tool_king
    Mar 29, 2010
    1,679
    road mechanic owner
    new jersey
    Update
    Yes we did. Had a electrical wiring connection issue in the dash that was causing the issue
  10. tool_king
    Mar 29, 2010
    1,679
    road mechanic owner
    new jersey
    I have had that on Terex before .Or when the switch fail the light says on .
  11. tool_king
    Mar 29, 2010
    1,679
    road mechanic owner
    new jersey
    This machine is hydro static.It is working .I drove it around and beat on a bit .Without any issues.
  12. excavator
    Oct 16, 2006
    1,029
    Pacific North West
    Did you ever find a service manual?
  13. tool_king
    Mar 29, 2010
    1,679
    road mechanic owner
    new jersey
    I did not yet .
  14. Txhayseed
    Dec 23, 2019
    151
    Texas
  15. excavator
    Oct 16, 2006
    1,029
    Pacific North West
  16. Txhayseed
    Dec 23, 2019
    151
    Texas
    Also wasn't that machine also rebranded by bobcat ?
  17. excavator
    Oct 16, 2006
    1,029
    Pacific North West
    Yes, I believe it was.
