575Rancher
I've got a chance to buy an International TD8 Series E Dozer. It needs an engine. Does anyone know where to get parts to fit a Cummins BT4 into this machine? I suspect the flywheel bolt pattern will be different, the crankshaft will need an adapter and the motor mounts will probably need to be changed.
Is there a conversion kit or, if not, where would I look for parts to make this happen?
Thanks!
Thanks!
