International Dresser TD20 Dozer DVT573 return line seals
Tennessee
Trying to find the return line seals for an International Dresser TD20 Dozer DVT573 diesel engine injectors.
Rough dimensions of the seal are.
.270" tall.
.475 OD
..25 ID (seals to the .250 OD return line)
Thank you so MUCH for any direction on where to get these or optional replacement seals!
Cheap "old" Geezer
The common theme here is Eastman Seals on return lines. Will be the same regardless of engine manufacturer as were common to all. Hard as rock with age and available from Dorman at any parts house that sells Dorman products.
