redneckracin
3.73 and 245 70 19.5 tires. 6th gear has been open for business for quite awhile now. How do I figure out if the driveshaft can take the rpm besides the obvious grenading.
What tongue and hitch do you have on that?
You have a lot of tongue weight. I have snapped a hitch receiver and broke a hitch with too much tongue weight. It only takes a rough road and it will let go. My receiver and draw bar on my F550 were rebuilt using 1/2 wall pipe and a solid steel draw bar bolted to a 20K receiver. I still would not want a skid steer sitting on it.
If a trailer has a 6" C channel frame - the channels will bend behind the rear wheel and they will bow out in the front half of the trailer. Check and see how far the clearance is from the u bolts to the frame when loaded. They can touch and rub.
Yours might be 8"s cant really tell.
I like the concept of a two speed rear end, but it gets scary when they get stuck between hi-lo. That probably doesn't happen very much anymore, but it certainly has the potential to.Why not find a two Speed Diff and slip that in it. Ratios are varied but certainly could come up with something. Just use lo side when need off the road or really heavy.
Truck has a proper 3/4" thick pintle plate welded to the frame, and gusseted. Truck frame shear strength would be the limiting factor long before the hitch gives out. 60k pintle on the truck. Wish the truck actually had a 2" receiver so I could move lighter trailers...Another project for another day.
Trailer is 8" C channel with a 50k lunette ring, double framed at the front. My skid is smaller than it looks - 7400lbs with bucket and full fuel. Full weight of the machine isn't on the tongue, at most there's 4k of tongue weight. Quite a well designed trailer actually, only gripe is the fenders are kinda thin, and the ramps have no spring assist...and they're about 150lbs...next trailer will be a touch longer too. But this was a good deal, so I can live with it for now.
When you have an automatic you don't usually shift the 2 speed on the fly like you do with a stick.
